Q1 All Models
Firmware Version: 02.61.84
Plugin Version: 566
S1 All Models
Firmware Version: 02.19.90
Plugin Version: 566
Z1 All Models
Firmware Version: 02.28.70
Plugin Version: 566
Z1 Lidar
Firmware Version: 02.18.16
Plugin Version: 566
Note: After updating the App, go to Profile > Settings > Clear Cache to clear the cache, then reopen the Roborock App to ensure it upgrades stably to the latest version.
1. Now Supports Overlap in Area Creation
-Supports overlap between Areas during creation to reduce missed mowing.
-Supports merging overlapping Areas into a single larger Area.
-Fixed an issue in which the map could not be saved when newly added Areas overlapped with the charging station or a Passage.
2. Now Supports Adjusting Mowing Direction
-Supports customizing the mowing direction and efficiency for the full lawn or for each Area separately. -Automatically adjusts direction and efficiency based on lawn terrain for improved mowing performance.
3. Now Supports Low Detection Zone
If there are passable areas (e.g., stone paths) that are likely to be mistakenly detected as obstacles, you can create Low Detection Zones there. The mower will then reduce visual obstacle avoidance and pass through them.
4. Now Supports Relocating the Charging Station
When the charging station is relocated, you can use this feature to update its position.
5. Others
-Supports renaming Areas for easier management.
-Optimizes the recovery strategy to improve pass-through success.
-Optimizes the re-mowing strategy to enhance overall mowing efficiency.
-Improves edge mowing for better results.
