You can set up mowing schedules in the app, and your mower will run automatically according to those schedules.
- Tap Settings, then open the Schedules page.
- You can add a new schedule using either of these two methods:
Method 1: Draw directly on the schedule grid
- On the Schedules page, tap and drag across the grid to select your desired start time and duration.
- Tap Add New Schedule, choose the area or zone you’d like to mow, then tap Save.
Method 2: Use the + button
- Tap the + icon in the top-right corner of the Schedules page.
- On the Add a Schedule screen, select the area or zone(s) you want to mow, set the start time and duration, then tap Save.
