Answer:
- Battery level — Shows the current battery charge as a percentage (e.g., “85”)
- Bluetooth connection status — Indicates whether the mower is connected to your phone via Bluetooth
- WiFi connection status — Shows whether the mower is connected to your home WiFi network
- 4G connection status — Appears only if a 4G module is installed; indicates whether the mower has an active 4G connection
- Lock status — Shows whether the mower is locked (preventing accidental operation)
- “STOP” sign — Displays when the mower is manually stopped or paused
- “OTA” sign — Appears during an over-the-air firmware update
- Specific error codes — Shown when an issue occurs; refer to the troubleshooting guide for details
- Continuous loop animation — Plays while the mower is powering on or off
- Continuously generated line — Appears during mowing, mapping, or returning to the charging station
- “TILT” sign — Displays when the mower is tilted beyond a safe angle (e.g., on uneven ground or lifted at an angle)
- “LIFT” sign — Shows when the mower is fully lifted off the ground
