Answer:
- Mowing area
Z series: Designed for larger lawns. For example:
- Z115 supports up to 1,500 m²
- Z130 supports up to 3,000 m²
- Z150 supports up to 5,000 m²
Q series: Best suited for smaller lawns.
- Q105 supports up to 500 m²
- Q110 supports up to 1,500 m²
- Driving speed
Z series: Offers higher mowing efficiency with two speed modes:
- Z115 and Z130: 0.45 m/s (Daily mode) to 0.6 m/s (Efficient mode)
- Z150: 0.6 m/s (Daily mode) to 0.8 m/s (Efficient mode)
Q series: Speed range is 0.4 m/s (Daily mode) to 0.6 m/s (Efficient mode)
- 4G communication & anti-theft module
Z series: Includes a built-in 4G module as standard — enabling remote monitoring, real-time alerts, and enhanced anti-theft protection.
Q series: The 4G module is optional and can be added separately if needed. - Climbing ability
Z series: Built for challenging, uneven terrain — can climb slopes up to 80% (38.7°).
Q series: Optimized for relatively flat lawns — maximum climbing ability is 45% (24°).
Cutting height adjustment
Z series: Adjust cutting height remotely using the app (electric adjustment).
Q series: Adjust cutting height manually using the buttons on the mower.
- Maximum mowing height
Z series: Up to 12 mm
Q series: Up to 10 mm - Battery capacity
Z series: Higher battery capacity across the range supports longer mowing sessions and fewer recharges:
- Z115: 6 Ah
- Z130: 7.5 Ah
- Z150: 10 Ah
Q series: Designed for smaller lawns with lower battery capacity, which may require more frequent charging when covering the same area:
- Q105: 4 Ah
- Q110: 4.6 Ah
Note: Actual charging frequency depends on several factors — including lawn size and condition, selected cutting height, working mode (e.g., Daily vs. Efficient), and weather conditions.
