Answer:
- Mowing area
Z series: Designed for larger lawns. For example:
- Z115 supports up to 1,500 m²
- Z130 supports up to 3,000 m²
- Z150 supports up to 5,000 m²
S series: Ideal for smaller lawns.
- S108 supports up to 800 m²
- S115 supports up to 1,500 m²
- Driving speed
Z series: Optimized for higher mowing efficiency.
- Z115 and Z130: 0.45 m/s (Daily mode) to 0.6 m/s (Efficient mode)
- Z150: 0.6 m/s (Daily mode) to 0.8 m/s (Efficient mode)
S series: Prioritizes slower, more precise control.
- S108 and S115: 0.4 m/s (Daily mode) to 0.6 m/s (Efficient mode)
- 4G communication & anti-theft module
Z series: Includes a built-in 4G module — no extra purchase needed.
S series: The 4G module is optional and can be added based on your needs. - Climbing ability
Z series: Built for complex or uneven terrain, with a maximum climbing ability of 80% (38.7°).
S series: Best suited for flatter lawns, with a maximum climbing ability of 45% (24°). - PreciEdge accessory
Z series: PreciEdge is available as an optional accessory.
S series: PreciEdge comes included as a standard feature. - Maximum mowing height
Z series: Up to 12 mm
S series: Up to 10 mm - Battery capacity
Z series: Higher-capacity batteries mean fewer charging stops for the same mowing area.
- Z115: 6 Ah
- Z130: 7.5 Ah
- Z150: 10 Ah
S series: Battery capacity is optimized for small to medium lawns. You may need to charge more often than with the Z series for the same mowing area.
- S108: 4.6 Ah
- S115: 6 Ah
Note: Actual charging frequency depends on factors like lawn conditions, selected cutting height, and working mode.
