Answer:
- Check if the app or your mower’s display shows any error codes—these can help pinpoint the issue.
- Check the RTK indicator light on your mower. It should be solid green. If it isn’t, try relocating the RTK reference station for better signal strength. (Only applicable to RTK models)
- Look around the area where the mower is operating. Large obstacles—like buildings, dense trees, tall fences, or other shelters—can weaken the RTK signal and affect accuracy. (Only applicable to RTK models)
- Make sure both the mower’s firmware and the app are updated to the latest version. This helps ensure optimal performance, including accurate boundary recognition.
- Uneven ground, wet grass (especially right after rain), or slippery conditions can cause the mower to slip or drift—potentially moving it outside the mapped boundary.
