Answer:
- Check if the app or your mower’s display shows any error codes—these can help pinpoint the issue.
- Check the RTK indicator light on your mower. It should be solid green. If it’s not, try relocating the RTK reference station to a more open area with a clear view of the sky.
—Only applicable to RTK models - Look around the area where the mower is operating. Large obstacles—such as buildings, dense trees, tall fences, or other shelters—can block or weaken the RTK signal. Try mowing in a more open space if possible.
—Only applicable to RTK models - Make sure both the mower’s firmware and the mobile app are updated to the latest version. This helps ensure optimal performance, accurate boundary recognition, and access to the latest features and fixes.
- Uneven ground, wet grass (especially right after rain), or slippery surfaces can cause the mower to slip or drift slightly—potentially moving it outside the mapped boundary. Wait for the lawn to dry and consider adjusting mowing schedules during or just after heavy rain.
