Answer: If your lawn mower’s wheels are leaving deep tracks on the grass, here are some simple fixes to try:
- Mow when the grass is dry: Wet grass and damp soil make it easier for the mower wheels to sink in, resulting in deeper tracks. Avoid mowing during or right after rain — wait until the grass and ground have dried out.
- Change your mowing pattern regularly: Mowing in the same direction every time can gradually compact the soil and flatten the grass in those areas, making tracks more noticeable over time. Try alternating between horizontal, vertical, and diagonal patterns each time you mow.
- Adjust the mowing height: Cutting the grass too short weakens it and makes it more likely to lie flat under the mower’s weight — which highlights wheel marks. Keep your grass at a moderate, healthy height to help it spring back more easily.
- Check and clean the wheels: Built-up grass clippings, mud, or debris on the wheels can reduce traction and cause them to dig in more. Wipe down the wheels before each use to keep them clean and rolling smoothly.
