Answer:
- Check the mower’s screen and the Roborock app to confirm that the Wi-Fi, 4G, or Bluetooth signal is connected and stable.
- Check the GNSS antenna’s indicator light — it should be a solid green color.
- Check for any available firmware or app updates. If updates are found, install them first.
- Remove the mower from the Roborock app, then re-bind it by following the setup process again.
- Restart both the Roborock app and the mower, then try the action again.
- If the issue still persists, try relocating the GNSS antenna to a spot with a clearer sky view, perform a new map calibration (remapping), and test again.
