Replacing the blades regularly is essential for maintaining optimal cutting performance, protecting your lawn, and ensuring the smooth operation of the mower.
Over time, dull or damaged blades tear grass rather than cutting it cleanly, which can damage lawn health. Installing fresh blades ensures a precise cut, promotes healthier grass growth, and improves energy efficiency during operation.
For the best results and safety, we recommend replace all blades and screws at the same time instead of replacing individual ones.
As blades wear down, they lose weight unevenly. Mixing new blades with worn ones creates an imbalance on the blade disc, which can lead to:
Reduced and uneven cutting performance
Increased machine vibration and wobbling
Unusual rotating noises and unnecessary wear on the motor
By replacing the entire set together, the mower can maintain proper balance, smooth operation, and optimal performance.
