Answer:
Note: The AirTag is a third-party device/accessory and must be purchased separately by the mower’s owner.
How to install an AirTag in 2WD models:
- Place the mower upside down on a soft, clean surface (e.g., a towel or carpet) to protect the blades and housing.
- Locate the battery compartment cover. Remove one screw next to the cover, then lift off the cover to open the compartment.
- Gently place the AirTag inside the compartment.
- Install the compartment cover back and secure it with the screw you removed in step 2. Installation is now completed.
