Answer:
- Mowing area
- LiDAR version (Z120 LiDAR): Supports up to 2,000 m².
- Non-LiDAR versions:
- Z115: Up to 1,500 m²
- Z130: Up to 3,000 m²
- Z150: Up to 5,000 m²
- Navigation
- LiDAR version (Z120 LiDAR): Uses built-in LiDAR for precise, active navigation—no external RTK antenna needed.
- Non-LiDAR versions (Z115, Z130, Z150): Require an external RTK antenna. For best performance, install it in a clear, unobstructed location with strong satellite signal reception.
- Battery and charging
- LiDAR version (Z120 LiDAR): Comes with a 6 Ah battery—ideal for medium-sized lawns. How often it needs charging depends on your lawn’s size, grass conditions, and mowing schedule.
- Non-LiDAR versions: Battery capacity varies by model:
- Z115: 6 Ah
- Z130: 7.5 Ah
- Z150: 10 Ah
Larger batteries help reduce the number of charging stops needed for bigger lawns.
Note: Actual charging frequency can vary based on factors like grass height, cutting settings, weather, and terrain.
