Answer:
- Mowing area
Z series: Best for larger lawns. For example:
- Z115 supports up to 1,500 m²
- Z130 supports up to 3,000 m²
- Z150 supports up to 5,000 m²
S series: Designed for smaller lawns.
- S108 supports up to 800 m²
- S115 supports up to 1,500 m²
- Driving speed
Z series: Higher speeds for greater mowing efficiency.
- Z115 and Z130: 0.45 m/s (Daily mode) to 0.6 m/s (Efficient mode)
- Z150: 0.6 m/s (Daily mode) to 0.8 m/s (Efficient mode)
S series: Slower, more controlled speeds—ideal for precision and safety.
- S108 and S115: 0.4 m/s (Daily mode) to 0.6 m/s (Efficient mode)
- 4G communication & anti-theft module
Z series: Includes a built-in 4G module—no extra purchase needed.
S series: 4G is optional and available as an add-on accessory, depending on your needs.
4. Climbing ability
Z series: Built for challenging, uneven terrain—can climb slopes up to 80% (38.7°).
S series: Optimized for flatter lawns—handles slopes up to 45% (24°).
5. PreciEdge accessory
Z series: PreciEdge is available as an optional accessory.
S series: PreciEdge comes included as a standard feature.
6. Maximum mowing height
Z series: Up to 12 mm
S series: Up to 10 mm
7. Battery capacity
Z series: Higher-capacity batteries mean fewer charges are needed to cover the same area.
- Z115: 6 Ah
- Z130: 7.5 Ah
- Z150: 10 Ah
S series: Battery capacity is tuned for small to medium lawns. You may need to recharge more often than with the Z series for the same mowing area.
- S108: 4.6 Ah
- S115: 6 Ah
Note: Actual charging frequency depends on several factors—including lawn size and condition, selected cutting height, and operating mode (e.g., Daily vs. Efficient).
