Answer:
Option 1: Built-in location features in the Roborock app
You can use the following tools directly in the Roborock app to locate your mower:
Go to Device → Settings → Security and Anti-Theft → Mower Location → Agree Privacy Policy
then tap Locate Robot or Play Sound.
- Go to Device → More → Security Settings → Anti-Theft Alarm, then toggle it On.
Once enabled, you can set a custom distance threshold for the alarm in the Virtual Boundary menu.
Option 2: Third-party tracking devices (e.g., AirTag)
You can also attach a third-party tracker—such as an Apple AirTag—to your mower. Your mower has a dedicated compartment designed specifically for this purpose, located inside the upper body.
To install the tracker:
- Remove the upper body cover of your mower.
- The cover is secured with simple buckles or clips and can be detached easily by hand.
- Unfasten 2 screws and remove the plastic lid.
- Place the tracker into the designated compartment.
- Tighten the 2 screws back.
- Install the upper body cover back properly.
Here’s where the compartment is located on the AWD mower:
Important note:
When reattaching the upper body cover, make sure it’s fully and correctly secured. Improper installation may block the binocular cameras—this can interfere with obstacle detection and avoidance.
