NRTK requires a stable, high-quality internet connection to work properly. Activation usually fails when the signal is weak or unstable. To fix this, simply make sure you are in an area with good network coverage. If it still doesn't work, try moving to a different spot or restarting your device’s network connection. Also clear cache and try again after 2-3 mins.
