The manual height adjustment has been upgraded to 7 gears (compared to RockNeo Q1). These 7 gears represent the cutting height and correspond to 25 mm, 30 mm, 40 mm, 50 mm, 60 mm, 70mm, 80mm respectively.
You can think of this height in two ways:
· As the distance from the ground – that is, the clearance between the cutting blade and the soil surface.
· As the grass retention height – the length of grass that remains on your lawn after mowing. Choose the setting that best fits your lawn type, the season, and your personal preference. And because it's manual, you have full control to change it whenever you like.
