Answer:
Passages can be created automatically or manually. If automatic creation fails or does not meet your needs, you can create manually by following the steps as below:
- On the Mowing homepage, tap Manage the Map icon.
- Tap [Passage], then select [Add].
- In this case, for example, we want to manually create a passage between areas. Users need to control the mower using the joystick, let the mower start from a spot within the first area, then tap 'Set a starting point'.
4. Control the mower, choose an appropriate path, drive the mower to the second area, once the mower is within the second area, the 'Save' button will appear. Click 'Save' to create the passage.
