Answer:
On a map, you can create up to three passages between any two areas—this includes both automatically and manually created passages.
However, passages connecting an area to a charging station are limited to just one per area. That means each area can have its own single, dedicated passage to the charging station—but not multiple.
If an automatic passage to the charging station fails to generate, you can always create a manual passage instead.
