Answer:
On a map, you can create up to three passages between any two areas—whether those passages are generated automatically or added manually.
However, there’s an exception for charging stations:
- Only one passage is allowed between any single area and the charging station.
- That said, each area can have its own dedicated passage to the charging station.
If an automatic passage between two areas doesn’t generate successfully, you can always create a manual passage instead.
