Failure to recognize the docking marker when trying to dock or undock
- Check whether dirt or stains are covering the docking marker or the mower’s dual-camera. If so, gently clean both surfaces with a soft, dry cloth and try docking or undocking again.
- Check whether direct sunlight is casting a shadow on the docking marker — this can interfere with recognition. To fix this, adjust the installation direction of the charging station so the marker stays in consistent, even lighting. Alternatively, consider purchasing the official garage accessory, which helps shield the marker from changing light conditions.
