Please stop the mower and disconnect the power supply.
Wear protective gloves and sturdy shoes, and put on long trousers.
- The PreciEdge module may be tangled with debris. Stop the mower, inspect the module, remove any debris, then restart the mower.
- The issue may occur if the grass is too tall or thick (higher than 10 cm). Try raising the cutting height setting and run the mower again.
- If the grass is significantly taller than 10 cm, manually trim it first—then resume mowing once the height is reduced to 10 cm or less.
