- Check the right front steering motor for any foreign objects (like grass clippings, twigs, or debris) and carefully remove them. Then try restarting the mower.
- The grass may be too thick or too tall for the mower to handle smoothly. Move the mower to a different area with shorter or thinner grass, then restart.
- If the error continues, mow your lawn down to its usual maintenance height first—this helps reduce strain on the motors—then try again.
