- Check whether the blade disc is jammed by foreign objects. In high-temperature conditions, a jammed blade disc is more likely to cause the motor to overheat.
- Turn off the mower, clear any debris from the blade disc, and then restart. If the main blade motor is overheated, move the mower to a cooler or shaded indoor location to let it cool down.
- Once the motor has cooled down, press the MOW button, then the OK button in sequence to resume the mowing task.
