- Check whether the PreciEdge module is jammed by foreign objects. In high-temperature conditions, a jammed module is more likely to overheat—and this can cause repeated errors. To fix it:
• Turn off the mower completely.
• Carefully remove any debris blocking the module.
• Restart the mower and test operation. - If the issue persists:
• Press the STOP button.
• Move the mower to a shaded or indoor area to let it cool down.
• Once cooled, try activating the module again—it should work normally.
