Answer:
Clean the mower regularly—as needed—to remove dirt, grass clippings, and debris from the wheels, cameras, cutting discs, and other components.
Before cleaning, please make sure that:
- The mower is powered off and unplugged (if applicable).
- The compartment cover screws are fully tightened to ensure the mower remains sealed and protected.
- You do not use gasoline, alcohol, or any other corrosive or flammable solvents—these can damage surfaces and internal components.
- Avoid using a high-pressure washer, as this may force water into sensitive areas and cause damage.
