To access this feature, please click through menus as below:
Enter detailed page--Manage the Map--More--Pattern--Pick pattern--Place it within map area--Save
Note:
- You can select a pattern type from those 12 icons listed in Roborock app.
- Use the button marked in the red box to reposition the pattern's direction.
- Use the square box with red dots to reposition the pattern's size.
- There is a minimum size limitation for each of those patterns, it would be enlarged, but when the lower limit of the area is reached, it cannot be manually reduced further.
- A pattern cannot overlap with No-Go zones, charging station, existing patterns or other map elements.
- A pattern should always be placed within the mapping area.
