Answer:
The battery’s lifespan depends on several factors, including how many hours you use it, how hard the mower works, the conditions where you mow (e.g., heat, humidity, terrain), and how well you store it when not in use.
If you notice a significant drop in runtime—such as the mower stopping much sooner than usual—it may be time to replace the battery. Please contact your local dealer or the RoboRock Customer Service team for assistance.
Some error codes related to the battery:
E22: Battery temperature is too high.
→ Move the mower to a cooler, shaded area.
→ The mowing session will automatically resume once the battery and motors have cooled to a safe operating temperature.
E23: Battery temperature is too low.
→ Move the mower to a warmer location (ideally above 0°C / 32°F).
→ The mowing session will automatically resume once the battery and motors warm up to a safe operating temperature.
E24: This error appears immediately on the screen after powering on the mower.
→ Check whether the battery has been recently replaced or repaired—or if a non-official (third-party) battery is installed.
→ If the issue continues, please contact your dealer or the RoboRock Customer Service team for further support.
⚠️ Warning: For your safety, do not attempt to replace or repair the battery yourself. Only authorized service personnel should handle battery replacement.
E104:
→ Try turning the mower off and then back on.
→ If the error returns, contact your dealer or the RoboRock Customer Service team for help.
Note: Charging may fail if the mower is placed in an environment that’s extremely hot (above 40°C / 104°F) or extremely cold (below 0°C / 32°F). For best results, move the mower to a room-temperature location (ideally between 10°C–30°C / 50°F–86°F) before charging.
